Author Topic: FyBBS  (Read 51265 times)
Re: FyBBS
« Reply #15 on: October 06, 2005, 12:42:41 am »
BY NOT KILLING ME DAILY MAYBE?
IceTyger
  • Internet Anthropologist
  • I'VE GOT LIKE FIFTY PICTURES LIKE THIS
Re: FyBBS
« Reply #16 on: October 06, 2005, 12:34:58 pm »
Doesn't affect alignment. /kill
Anyway, in Bonetown there's a few random encounters that can affect your alignment. Well, more than out on the field at least.
tightly hold your hand
take a deep breath
give them the finger
are you worried that your thoughts are not quite clear
Re: FyBBS
« Reply #17 on: October 07, 2005, 12:09:15 pm »
I tweaked some of the BBS code again, since the thing runs so shitty sometimes, and I think PERHAPS I've made it much more tolerable to play when multiple people are on.  Let me know if you notice any difference!
Joefus
  • Click Out Field Commander
  • Heehehe
Re: FyBBS
« Reply #18 on: October 07, 2005, 01:09:39 pm »
What ever you did it sure did speed things up.  Usually it's pretty fussy on my computer but just now it played fine and worked with no problems or lag.
Re: FyBBS
« Reply #19 on: October 10, 2005, 06:32:38 pm »
no problems here
Ciono
  • Coffee Fiend
  • Fybar Wannabee
    • In Praise of Folly
Re: FyBBS
« Reply #20 on: October 11, 2005, 07:43:20 am »
Whatever you did, I can't play on the school comps anymore...something about not being able to access some file. Makes me very sad inside, cause not all the stuff shows up on my Mac.
Edit: Exact error reads - ./dosemu.bin: error while loading shared libraries: libx11.so.6: cannot open shared object file: No such file or directory
« Last Edit: October 11, 2005, 07:50:22 am by Ciono »
Booyaka
Joefus
  • Heehehe
Re: FyBBS
« Reply #21 on: October 11, 2005, 11:34:52 am »
Yeah I get that same error message when I try to load any of the games on both the Java version and the other one (forget it's name at the moment).
Re: FyBBS
« Reply #22 on: October 11, 2005, 02:31:31 pm »
Yeah that was a recent error that I caused last night/this morning actually.  I was removing a bunch of software which is just a waste of space on that machine and apparently dosemu was compiled with its tentacles attached to some of it.  So I recompiled it without that stuff and it's working o-kay now it seems.  It might even be a little better without loading that extra stuff into memory.
Re: FyBBS
« Reply #23 on: October 11, 2005, 05:41:39 pm »
thats why the website wasnt working right
Re: FyBBS
« Reply #24 on: February 02, 2006, 09:39:55 pm »
It's probably something I shoulda done a long time ago, but I updated the code to mask your password with asterisks so that nobody can see you type it in.
