If it helps, Fyber has done some rom creation and rom hacking himself in the past (not much but...)
If you feel you're hurting for a place to put it, provided you have a topic you want to raise, the software board would probably be a pretty good place for it. Fybertech projects really relates more to the 'fybertech' fictional universe, software would be a much better place to put your orriginal work.
Also don't worry, the fact that you enjoy the comics is enough for us, not everybody has to be a producer. Simlarly on the tech stuff, Some of what Fyber does even goes above my head (and I wouldn't doubt vice versa at times.) The point is, just enjoy yourself.
