Author Topic: FYBENG  (Read 26644 times)
FYBENG
« on: May 18, 2007, 07:45:05 pm »
FybertechBattleENGine.
A RPG system for IRC found in #beng.
You can say 'beng help' the name of anything to get info on items, weapons and monsters.
To start of say 'beng help classes' to view what you can become.
Then "beng join [CLASS]' to become it.
You start off in the rest position so to wake up say 'Beng wake' to join the active party.
To go back to sleep say 'beng rest', resting restores your hp and mp to full after 30 seconds.
'beng stat' pulls up your character sheet so you can see your stats.
'beng weapstore' shows you a list of what weapons yoou can buy according to your class and gold count.
'beng equip [WEAPON]' makes the weapon your current choice.
'beng itemstore' is the same for items.
'beng inv' shows what you have on you right now in your inventory
'beng buy/sell [ITEM/WEAPON]' to buy or sell the item or weapon.
In order to fight you need to find a place first, say 'beng help areas' to see what is available.
Then say 'beng wander [AREA]' to encounter a random monster in that area.
To attack say "beng hit monster' or to run away 'beng flee'.
Once you get some spells and abilities you can use 'beng cast [SPELL] monster/[PLAYER]'
use 'beng use [ITEM] [PLAYER/MONSTER]' to use items.
I can add classes and weapons and items as needed.  So any suggestions for stuff is welcomed.
Re: FYBENG
« Reply #1 on: June 12, 2007, 11:52:11 pm »
VERSION 1.1 is ready for play
Your classes are
gunner- uses fire and normal type damage
detective=>not much in skills, but has the HUNT ability which allows to track down specific monsters in a specific area.
ninja=>uses many elemental attacks
robot=>resistant to fire and ice but weak to LIT, which happens to be its attack skill
scientist=>uses Chem type attacks, low hp but high MP
medic=>Can heal and some holy spells
cyborg=>physcial strength skills with high hp
thief=>special class that gains power as it grows
Re: FYBENG
« Reply #2 on: June 14, 2007, 11:54:05 am »
Is all about location location location.
easy
fybertech
forest
downtown
medium-easy
desert
tundra
jungle
medium
factory
valley_of_flames
necropolis
medium-hard
lost_city_atlantis
labryinth
hard
final_level
dragons_den
The objective of BENG is to beat final_boss in the final_level.  Best of luck to you!
« Last Edit: June 16, 2007, 10:09:03 pm by Sterling »
Re: FYBENG
« Reply #3 on: June 14, 2007, 03:41:27 pm »
Version 1.2
some monsters can now drop items.
buffed up a few monsters in terms of HP.
upgraded some weapons.
Other commands
Beng graveyard - shows you who is dead.
Beng active - tells you who is in the active party
Beng dropped  - tells you what items monsters have dropped
Beng pickup [ITEMNAME] - places said dropped item into your inventory
Beng give [ITEMNAME] [PLAYERNAME]- Gives item in your inventory to said player.
« Last Edit: June 14, 2007, 03:52:01 pm by Sterling »
Re: FYBENG
« Reply #4 on: June 15, 2007, 06:01:00 pm »
version 1.3
Fixed some more spells.
beng front - puts you up front
beng back - puts you in the back
people in the front or twice as more likely to be hit then people in the back.
beng duel - challenge someone to a duel
beng record - tells you your dueling record
and yes, dueling someone does kill them.
« Last Edit: June 16, 2007, 10:10:47 pm by Sterling »
