Author Topic: Website probelms and suggestions.  (Read 20244 times)
  • Moderator
« on: February 23, 2007, 08:01:45 pm »
Post here if you have a problem with www.hindsight20xx.com, or if you have a suggestion of some kind that you think will make the site just a bit more awesome.
Any technical type problems might be put in Fyber's "To do" box which coincidently doubles as a trashcan.
I, Vito, will handle any style suggestions. Handling will most likely be me telling you to stfu though, or me saying good idea and possibly implementing. Take the chance and dance.
Rotary_Turbo
  • Corner Carver
  • Coolbert
  • I like RX-7s that have forced induction!
Re: Website probelms and suggestions.
« Reply #1 on: February 23, 2007, 10:22:01 pm »
NO PROBLEMS :D .  ...and, I can't really think of anything to suggest, so...
Gooder job on der site Fyber, and awesome comics stuffs Vito...*waiting for Vito's next case*
[00:48] <@FyberOptic> time to download 5790 spams
[00:49] <@FyberOptic> what a sad place the internet is to deliver so much useless data
[00:52] <@FyberOptic> 5790 porns would be such a much better use, for example
