Author Topic: The HEAT Is On  (Read 94280 times)
The HEAT Is On
« on: January 19, 2007, 08:27:32 pm »
Well, when im making stories, its not just gonna be all in one comic. Each story will have its own name. So heres my first story.
#1
« Last Edit: January 21, 2007, 04:07:09 pm by Rhythm »
Re: Hows the weather up there?
« Reply #1 on: January 19, 2007, 10:03:06 pm »
You better have a damn good reason for naming it "how's the weather up there".
HEAT Fest
« Reply #2 on: January 20, 2007, 09:33:06 am »
*Rhythm never answers*
Fixed up #1, But im not changing anything else, armatures eye (not Eye"s" because its a side view) is gonna stay the same since I attempted to fix it and it looked like crap so im leaving it the way it is. Word bubbles are fixed. And im not fixing anything else on this comic case when i opened it all the layers were merged, so I cant change anything else. PS: I changed it to GIF.
« Last Edit: January 20, 2007, 09:42:06 am by Rhythm »
Re: HEAT Fest
« Reply #3 on: January 20, 2007, 12:14:50 pm »
No offense, but "HEAT Fest" is worse than what you were using before.  If you want to use HEAT for whatever reason, make it catchier, like "Can't Take the HEAT", etc.  Even that's arguably not very good..!
Re: HEAT Fest
« Reply #4 on: January 20, 2007, 01:51:32 pm »
I'll think of something eventually. Meanwhile, heres #2.
Re: HEAT Fest
« Reply #5 on: January 20, 2007, 05:18:16 pm »
Here ya go.
Re: HEAT Fest
« Reply #6 on: January 20, 2007, 11:33:31 pm »
#3
« Last Edit: January 20, 2007, 11:35:02 pm by Rhythm »
Re: HEAT Fest
« Reply #7 on: January 20, 2007, 11:52:10 pm »
Prediction! Fyber drops the field dropping the cronies.
The HEAT is on
« Reply #8 on: January 21, 2007, 03:47:20 pm »
Damn spoilers  :(
#4
« Last Edit: January 21, 2007, 03:53:50 pm by Rhythm »
Re: The HEAT Is On
« Reply #9 on: January 21, 2007, 10:16:12 pm »
Remove the line in front of my earpiece. It looks better without.
Re: The HEAT Is On
« Reply #10 on: January 23, 2007, 09:56:14 am »
Since Rhythm claimed he couldn't fix this, I went ahead and did it.
Re: The HEAT Is On
« Reply #11 on: January 23, 2007, 12:05:03 pm »
Heres #5, don't worry armature, your turns coming up.
Re: The HEAT Is On
« Reply #12 on: January 25, 2007, 05:02:56 pm »
#6, no animation cause I didnt feel like it.
Re: The HEAT Is On
« Reply #13 on: January 28, 2007, 03:27:57 pm »
#7
Re: The HEAT Is On
« Reply #14 on: January 29, 2007, 07:54:13 pm »
#8 THERES A RUMBLE COMING
« Last Edit: January 29, 2007, 09:11:11 pm by Rhythm »
