Author Topic: A FyComic  (Read 21211 times)
A FyComic
« on: January 19, 2007, 04:00:32 pm »
Well, I guess im gonna make the first Fybertech Adventure comic. But there are Still some blanks to be filled so imma gonna need help. Heres a list of what i got and need.
Title: BLANK
Story: I have one in mind, but if you have any please share, Im gonna need them.
Place: Well, I'm gonna be using 8-bit game backgrounds for other areas. Fylab is gonna be custom.
But I need help deciding. The 8-bit Kirby back ground or metroid? Or one from a game that looks good for the sprites imma using. Use this place plz. http://www.vgmaps.com/
Characters:
Vito (on a rare ocasion)
Rhythm
Shadow
BlueJay
Armature
Prox (pending)
MDude (pending)
Comic strip size: dont know yet
Re: A FyComic
« Reply #1 on: January 19, 2007, 06:52:46 pm »
Before you do any mroe work. Come up with a story and premise. Don't just make a comic with fybertech charatcers, to just make a comic.
Re: A FyComic
« Reply #2 on: January 19, 2007, 08:35:44 pm »
Baloon tail.
Created by Senor Booyah.
« Last Edit: March 24, 2007, 06:12:03 pm by Armchair »
Re: A FyComic
« Reply #3 on: January 19, 2007, 09:40:23 pm »
Isn't that Booyah's?
Re: A FyComic
« Reply #4 on: January 19, 2007, 10:02:12 pm »
Yes, well, we can't have no more of those 45-degree points. They're just too unclassy.
Also, yes, get the story first thing. The title can wait until last, or can be something supersimple like "Fybertech". As for the backgrounds, I would just suggest you just edit some mega man backgrounds to make them look less cartoony and more utilitarian. I can help you here, I've got a few edited backgrounds from that old comic I tried to make. Also check http://www.sprites-inc.co.uk/, they have some choice bits that can't be found on vgmaps.
AS FOR THE COMIC SIZE, this really doesn't matter too much. Whatever you think will give you enough room to fit everything you need. I'd suggest the old hazlabs standard of 250x150, but if you really need space, you could probably bump it up to 300x200.
Also, if you're going to put all those people in there, you'd better make sure we all have pretty similar sprites, or else it'll be a disaster. If you were going to use those big tall sprites Boris made, I would suggest 1) that you make them shorter, or 2) that you make the frame a little bit bigger to accommodate them.
Back to the story, I think it would be a good idea to just start off with Fyber, add Boris, then Vito, and then find different ways to introduce everybody else. This could be just an exposition comic, and then whatever story arc you wanted to go after could be a completely separate comic.
O-okay, I'm d-d-done-
* Prox starts gasping for breath
« Last Edit: January 19, 2007, 10:04:14 pm by Prox »
Re: A FyComic
« Reply #5 on: January 20, 2007, 09:11:47 am »
Well, Vito said himself he probably should only come in on a very rare occasion. Boris Helped me with the comic size. Word bubbles I know what to do now thanks to Graft and Boris. Sprites are gonna be similar because im the one making them so they match my style of spriting. Also, I'm starting out With Fyber, Dr. Graft and Me because those are all the sprites I have at the moment. What I was thinking is having 2 teams, one lead by fyber, and one lead by Boris since they dont exactly know the way. Also, i may be changing Boris's look, Im not sure, I have to talk to him about it at some point today.
