This is a Work in progress.
Gender: Explanatory
Race: Pick pretty much any race you want. You can make up your own or pick any pre-made race. I.E. Namek, Saiyan, Android, Changeling (Think Freiza's race), even a Kai!
http://www.myfavoritegames.com/dbz/Species.htmPhysical Description: Again, easy here. Try to be pretty detailed.
Mental/Style: If you've done this before, you know what to expect. For those that haven't, supply their personality and adhere to it during the RP. Then follow up how the character acts in battle.
History: Brief or long. Make it readable.
Ki Color: What color is your charging aura? The blasts?
Basic attacks: Gimme three basic attacks, either physical or ki-based.
Super: What's your super move? You need max Ki to pull this off, you can't use it as the first move in most situations.
Ultimate: What is your end-all move? You need max Ki, can't use it as first move, ever. Once you use it, hit or miss, you have to sit it out a round or two.
Equipment: 2-3 pieces. Weapons, Armor, Scouter, whatever.
Stats: I'm going to try and be basic. You have HP, Ki, Attack, Defense, Flight, and a 6th option for you to make. You have 15 points to spend and start with 5 HP.
Power Level: It's not over NINE THOUSAAAAAANNND. Everyone starts at 10. Once you get started on your path you may and likely grow by leaps and bounds.
HP: How many hits you can take before a nap. 0 means you are knocked out, if you are attacked with a super or ultimate blast, your character is dead.
Ki: How much energy you have to use in the form of attacks. A single Ki ball takes 1 Ki. Flying also takes X Ki a turn depend on your level. You gain 1 Ki by hitting someone with your fists, feet, or other body part. You can also take a turn to charge 2 Ki. This can be modified by your 6th ability.
Attack: You add AP onto your attack roll. You add this onto your physical attacks.
Defense: You subtracts your DP from your attacker's roll.
Flight: 1, you can fly. It also drains 2 energy per turn. 2, drains 1 energy. 3, no energy drain. Some of your moves can only achieve 100% effectiveness while flying.
Your Sixth Sense. I mean Stat: You can make it a racial skill, ki reduction cost. Pretty open-ended. Some examples are, Regeneration, Bonus to attack, evasion.
!!IMPORTANT!! If you decide to go with a transforming character, that is your sixth skill.
