Author Topic: YOUR AGE BY CHOCOLATE  (Read 17234 times)
Earthquake
« on: September 21, 2006, 07:35:16 pm »
    YOUR AGE BY
    Chocolate
    MATH
    This is pretty  wild!
    DON'T CHEAT BY  SCROLLING DOWN FIRST!
    It takes less than a minute so work  this out as you read.  Be sure  you don't read the bottom until you've worked it out!
    This is not one of those waste of time  things, it's fun.
    1. First of all,  pick the number of times a week that you would like to have  chocolate
    (more than once but  less than 10)
    2.  Multiply this number by 2 (just to be bold)
    3. Add  5
    4. Multiply it by  50 -- I'll wait while you get the calculator
    5. If you have  already had your birthday this year add 1756 .....
    If you haven't, add  1755.
    6. Now subtract the  four digit year that you were born.
    You should have a  three digit number
    The first digit of  this was your original number
    (i..e., how many  times you want to have chocolate each week).
    The next two  numbers are
    YOUR AGE! (Oh YES, it  is!!!!!)
    THIS  IS THE ONLY YEAR (2006) IT WILL EVER WORK, SO SPREAD IT AROUND WHILE IT  LAST!!!
size=2 width="100%" align=center>
Yo
Re: YOUR AGE BY CHOCOLATE
« Reply #1 on: September 21, 2006, 07:35:46 pm »
I SMELL SPAM..!
« Reply #2 on: September 21, 2006, 07:43:08 pm »
Do it anyway, its freakin creepy. It guessed my age right...!
« Reply #3 on: September 21, 2006, 07:52:24 pm »
You realise it's a umbers trick, try all the numbers 1 - 10 I bet they all end up as your age and guessed #
« Reply #4 on: September 21, 2006, 07:56:13 pm »
PRO TIP: THE "AGE" FUNCTION IS ONLY REALLY BASED ON TWO NUMBERS, BIRTH YEAR AND 1755 OR 1766. The times 50 is to ensure the chocolate number add to it pushes the number over the year of your birth so the result doesn't come out negative and mess up the last two digits.. The chocolate per week number only really determines the hundreds collumn. The reason it has to be 1<x<10 is you'd go out of range and the last two digits would no longer be right. Mash them together and fool people who arn't geeks like we are~
« Last Edit: September 21, 2006, 07:58:57 pm by Boris »
« Reply #5 on: September 21, 2006, 07:57:38 pm »
THE MORE YOU KNOW!
« Reply #6 on: September 22, 2006, 01:42:59 am »
I was about to call foul since it gave me the wrong age, but then I went back and recalculated to make sure, and that's all it was.  Perdy cool trick, though!
