Author Topic: GameServ  (Read 16545 times)
GameServ
« on: December 08, 2005, 01:59:19 pm »
If you've been on IRC yet, you might have noticed a new user sitting in the channel: GameServ.  When I was looking for info on making server link stuffs, I found a few bots one can connect directly into the server, and this one promised to play similar to LORD, so I thought it was worth a try.  When I first started messing with it, it hated color in any command you typed, but I was able to easily enough edit the code and recompile to strip that out.
Anyhoo, to get started, you can message it and type "help".  You can use "help" in front of any command name from that point to find out more info.  The one you'll want to start with is "register", and then everytime you want to play afterwards, you'll need to "identify" to it (much as you do to Nickserv).  To actually play, you can use "search", for example, to find mawnsters to attack, and just respond with "attack" to fight back, etc.  It seemed like it might be fun, so we'll see how it goes!
Ciono
  • Coffee Fiend
  • Fybar Wannabee
    • In Praise of Folly
Re: GameServ
« Reply #1 on: December 08, 2005, 02:11:54 pm »
It's fun.
Booyaka
Re: GameServ
« Reply #2 on: December 08, 2005, 02:25:13 pm »
Seems fun. We'll have to wait a bit to see how it works out, tho.
Re: GameServ
« Reply #3 on: December 11, 2005, 08:10:04 pm »
How do you work it?
Re: GameServ
« Reply #4 on: December 11, 2005, 08:32:22 pm »
Should I requote the first post or something?
Ciono
  • Coffee Fiend
  • Fybar Wannabee
Re: GameServ
« Reply #5 on: December 11, 2005, 08:44:36 pm »
Second level is me
Booyaka
Re: GameServ
« Reply #6 on: December 11, 2005, 08:49:40 pm »
here we go, now i know what to do.
