Author Topic: Ball Bouncery - Source Code  (Read 22822 times)
« on: November 04, 2004, 01:12:38 am »
#include <gb/gb.h>
#include <stdio.h>
#include <string.h>
#include <gb/drawing.h>
#include <gb/sample.h>
#include <time.h>
#include "tiles.c"
#include "haztiles.c"
#define MAXVEL 10
unsigned char tilemap[32 * 32];
unsigned char hazmap[] = {1, 1, 1, 2, 3, 4, 5, 4, 6, 7, 8, 4, 9, 10, 2, 11, 12, 13};
void main()
INT16 j,i;
INT16 x, y, xvel, yvel;
INT8 scrolldir;
UINT16 oldtime, currenttime;
DISPLAY_ON;
HIDE_WIN;
HIDE_BKG;
HIDE_SPRITES;
delay(1000);
set_bkg_data(0, 14, HazTiles);
set_bkg_tiles(1, 0, 18, 1, hazmap);
scroll_bkg(0, 10);
SHOW_BKG;
scrolldir = -1;
for (i = 0; i < 75; i++)
  scroll_bkg(0,scrolldir);
  delay(50);
delay(3000);
move_bkg(0,0);
printf(" \n");
printf("\n\n\n\n");
printf("  SUPA BAWL BOUNCE\n");
printf("\n\n");
printf("   By: FyberOptic");
printf("\n\n\n\n\n\n\n");
printf("    Press a key");
waitpad(0xFF);
waitpadup();
OBP0_REG = 0x27U;
set_bkg_data(0, 5, GameTiles);
for (j = 0; j < 32 * 32; j++) tilemap[j] = 0;
set_bkg_tiles(0, 0, 32, 32, tilemap);
set_sprite_data(0,5,GameTiles);
set_sprite_tile(0,1);
x = SCREENWIDTH / 2;
y = SCREENHEIGHT / 2;
xvel = 2;
yvel = 0;
SHOW_SPRITES;
while (1)
        i = joypad();
        if(i)
          if(i & J_UP) yvel -= 1;
          if(i & J_DOWN) yvel += 1;
          if(i & J_LEFT) xvel -= 1;
          if(i & J_RIGHT) xvel += 1;
        if (xvel > MAXVEL) xvel = MAXVEL;
        if (yvel > MAXVEL) yvel = MAXVEL;
        x += xvel;
        y += yvel;
        if (x > 160) {x = 160; xvel = -xvel; }
        if (x < 7) {x = 7; xvel = -xvel; }
        if (y < 15) {y = 15; yvel = -yvel; }
        if (y > 152) {y = 152; yvel = -yvel; }
        move_sprite(0,x,y);
        delay(60);
Re: Ball Bouncery - Source Code
« Reply #1 on: November 04, 2004, 01:13:04 am »
 HAZTILES.C
 Tile Source File.
 Info:
  Form                 : All tiles as one unit.
  Format               : Gameboy 4 color.
  Compression          : None.
  Counter              : None.
  Tile size            : 8 x 8
  Tiles                : 0 to 13
  Palette colors       : None.
  SGB Palette          : None.
  CGB Palette          : None.
  Convert to metatiles : No.
 This file was generated by GBTD v2.2
/* Start of tile array. */
unsigned char HazTiles[] =
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x44,
  0x54,0x54,0x28,0x28,0x28,0x28,0x00,0x00,
  0x00,0x00,0x18,0x18,0x18,0x18,0x00,0x00,
  0x00,0x00,0x00,0x00,0x24,0x24,0x24,0x24,
  0x3C,0x3C,0x24,0x24,0x24,0x24,0x00,0x00,
  0x00,0x00,0x00,0x00,0x18,0x18,0x24,0x24,
  0x00,0x00,0x00,0x00,0x38,0x38,0x08,0x08,
  0x10,0x10,0x20,0x20,0x38,0x38,0x00,0x00,
  0x00,0x00,0x00,0x00,0x38,0x38,0x24,0x24,
  0x38,0x38,0x24,0x24,0x24,0x24,0x00,0x00,
  0x24,0x24,0x24,0x24,0x38,0x38,0x00,0x00,
  0x00,0x00,0x00,0x00,0x20,0x20,0x20,0x20,
  0x20,0x20,0x20,0x20,0x3C,0x3C,0x00,0x00,
  0x38,0x38,0x24,0x24,0x38,0x38,0x00,0x00,
  0x00,0x00,0x00,0x00,0x1C,0x1C,0x20,0x20,
  0x18,0x18,0x04,0x04,0x38,0x38,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x20,0x20,0x20,0x20,0x18,0x18,0x00,0x00,
  0x24,0x24,0x24,0x24,0x18,0x18,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x14,0x14,
  0x2A,0x2A,0x22,0x22,0x22,0x22,0x00,0x00
/* End of HAZTILES.C */
« Reply #2 on: November 04, 2004, 01:13:24 am »
 TILES.C
 Tile Source File.
 Info:
  Compression          : None.
  Counter              : None.
  Tile size            : 8 x 8
  Tiles                : 0 to 5
  SGB Palette          : None.
  CGB Palette          : None.
unsigned char GameTiles[] =
  0xFE,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFB,
  0xFF,0xFF,0xFD,0xFF,0xBF,0xFF,0xFF,0xFF,
  0x00,0x00,0x00,0x3C,0x3C,0x5A,0x3C,0x7E,
  0x3C,0x7E,0x3C,0x5A,0x00,0x3C,0x00,0x00,
/* End of TILES.C */
« Reply #3 on: November 04, 2004, 01:13:41 am »
OKAY SO there you go.  I believe that's pretty much everything.  I could have modified the source after I compiled the ROM, to test other junks, but I believe I fixed it back to how it should go.  I created the tiles there for this ROM too, so I figured I'd include those files as well, in case you actually did want to compile it.
Also, this was done with the GameBoy Developers Kit, which may have been updated since I last downloaded it.  But I recommend it to anyone wanting to develop ROMS for the GB and GBC.
