Author Topic: Show off your sprites!  (Read 262905 times)
magus
Re: Show of your sprites!
« Reply #60 on: December 01, 2005, 08:30:37 pm »
With what?
« Reply #61 on: December 01, 2005, 08:45:42 pm »
* Prox locks magus in the quick reply box
Make sure your sprites and avatar are either .JPG, .PNG, or .GIF before posting them. That's the cause of 80% of all problems.
« Reply #62 on: December 01, 2005, 10:19:09 pm »
Harpuia, the link you put to your avatar is:  http://www.http.com//www.inti.co.jp/cd/zero1/image/harpuia.jpg , which is clerly a bad url.   The link you want, it would seem, is http://www.inti.co.jp/cd/zero1/image/harpuia.jpg .  Though that image is a bit big, so I don't know if it'd make a very good avatar unless you edit it.
Also, I added .jpeg to the list of file extensions one can upload, since I noticed the other day when I tried to upload such a file, it yelled at me.  I think it's dumb to name a file .jpeg, really, but sometimes they are and I forget to rename'em and then I type out paragraphs like this explaining it and SOMEBODY MAKE ME STOP.
« Last Edit: December 01, 2005, 10:20:46 pm by FyberOptic »
« Reply #63 on: December 01, 2005, 11:19:41 pm »
lol @ Fyber.
« Reply #64 on: December 02, 2005, 08:53:20 am »
try making your avatar 100x100 pixels
« Reply #65 on: December 02, 2005, 12:01:43 pm »
Yeah that sucks, I have to shave down some of my old avatars now.
« Reply #66 on: December 02, 2005, 10:36:40 pm »
For der record, 100x100 was also the avatar limit on the hboard, as well.
« Reply #67 on: December 04, 2005, 12:08:30 am »
I thought it was 120x120 Fyber, cause that's what all my avatars are.... unless I just changed it so little that it got in only cause before change.
« Reply #68 on: December 08, 2005, 06:45:33 pm »
TIME TO SHOW OF A SPRITE
If this is actually to be my character, it'll take a lot of backstory to make him so. However, I think the sprite looks a-pretty-pretty good~
If there are any possible corrections, please let me know.
« Reply #69 on: December 09, 2005, 03:14:30 pm »
He looks pretty good, but maybe a little too tall. I dunno what you really intend to use him for, if it's just for avatars and such than good, but if you intend to use him in comics you may want to bring him down so he won't be twice as tall as the megaman edits which is generally the standard with most.
« Reply #70 on: December 09, 2005, 03:55:26 pm »
Give him a kimono and a sword and he could be a samuri!
« Reply #71 on: December 09, 2005, 04:03:30 pm »
FOOL! he is the king of pop-and-lock!
« Reply #72 on: December 10, 2005, 01:26:14 am »
make me scary
« Reply #73 on: December 11, 2005, 03:16:52 pm »
heres somethin i made for Mdude
« Reply #74 on: December 11, 2005, 05:06:13 pm »
that actually looks pretty good.
