Author Topic: Show off your sprites!  (Read 263716 times)
Re: Show off your sprites!
« Reply #180 on: August 19, 2006, 09:39:41 pm »
Don't have to quote it.
Just say "Thanks Fyber!"
« Reply #181 on: September 09, 2006, 12:16:54 pm »
I tried,
« Reply #182 on: September 09, 2006, 04:24:05 pm »
That's way to buff looking to be fyber.
« Reply #183 on: September 09, 2006, 05:58:37 pm »
I'll have to get Mysto to design my robot body when I become rich and have my current body replaced.
This isn't so much a sprite, but Mysto wanted a background pattern, so I thought it might be useful to others.
It looks kinda like girders if you double-size it.  And folks could change the girder and blue thing color depending on the thing they're using it as a background for.  Not sure if I'd change the gray though.
« Reply #184 on: September 10, 2006, 12:45:01 pm »
Heres a better FyberOptic Sprite I made. I don't know if this one could replace the official one in the spritery. If this one is good, ill see if i can make a sheet.
« Last Edit: September 10, 2006, 12:53:29 pm by Rhythm »
« Reply #185 on: September 10, 2006, 02:30:46 pm »
Those are both pretty good, Mysto.
« Reply #186 on: September 10, 2006, 04:45:39 pm »
That'ns lookin good.
Blazeman
  • BOMBING DOES NOT WORK THAT WAY!
    • Children of Crisis [FF7 RP]
« Reply #187 on: February 05, 2007, 09:06:29 pm »
Sorry for the bump, but I just wanted to add my sprite sheet that I've had sitting on my computer since well before anyone even heard of Megaman ZX. On the spritesheet, it mentions something about a "Polymorphic Armor". This equipment has been described in the ULTIMATE BATTLE, but he does not have it in the RPs because of two things:
1. It would make Chris too powerful, especially as a level 1,
2. The technology behind it is different from the HEAT-based armors, and would not fit in Fybertech canon...unless Fyber makes it so it can.
The armor uses nanotechnology to build and rebuild the armor to whatever design Chris wishes, as long as he has the data for it. To get that data, he needs to "scan" a character for it. This takes only a few seconds. However, from that scan, the system needs some time, usually 30 minutes, to process the data into a form usable for the armor.
The armor that Chris gets off of a character will be based off of that character, but it won't be a perfect match. The armor cannot resize itself if the character is much bigger or smaller than Chris, as only the armor can change shape, and not its wearer. The appearence of the armor would be akin to wearing a costume of the character, standing at around 5'8" tall (Slightly taller than Chris's normal height, due to boot and helmet thickness.)
The armor's "default" state, where it is not based off of another character, is all gray, and shaped similarly to that of Megaman X.
As for the risk of having the gauntlet taken from him...the gauntlet will only work if the genetic signature of whoever is wearing it matches that of whoever wore it first, which is Chris. A mismatch would be penalized with electric shocks that will either force the person to remove it, or cause nasty effects such as paralysis or death by electrocution.
Deck
« Reply #188 on: February 18, 2007, 06:19:59 am »
This is one I did WAAAAAY back in the old internet days, Bob and George and all that. I basically just took the wings off a Pegasus Maverick and stuck them on this guy. I THINK I did it for every sprite I found on the sheet.
« Reply #189 on: February 19, 2007, 12:09:15 pm »
Slick.
ahnna
  • Sasuke Uchiha
« Reply #190 on: April 05, 2007, 03:45:11 pm »
^^ Here
Mage
  • Veteran Lurker
« Reply #191 on: July 22, 2007, 03:21:00 pm »
Decided to add to some of those Fybertech Pokemon League badges I made a little while back.
Badge names(and who they belong to) are in left to right order:
Dark Eye Badge= Mage(myself)
Iron Cross Badge= Mets Armature
Twilight Badge= Sterling Gospel(you people call yourselves silly names)
Frequency Badge= Rhythm
Physics Badge= Fyber
Soaring Badge= Bluejay
Investigator Badge= Vito
Mech Badge= Boris
Feel free to steal or mess with these however you see fit.
« Last Edit: July 29, 2007, 09:19:57 am by Mage »
<INSERT PATHETIC ATTEMPT AT A WITTICISM HERE>
« Reply #192 on: July 28, 2007, 09:32:00 pm »
Twilight Badge is done by Gospel, my other persona.
And Sprites Ill probably never use from the ADV! RPG.  Lumi and Tesla were the next two that I was doing when I lost the will to continue due to everyone else, even our manager creator, leaving.
Lark
  • Professional Lurker
  • Coolbert
« Reply #193 on: March 28, 2008, 10:51:20 am »
Yes, I know the topic's been dead and collecting dust for months.  BUT, I figured this little thing wasn't worth making a new topic for or anything like that.
Yes, I just modified one of Rhythm's sprites.  I think it was the Bluejay one originally, but I swiped ideas from a handful of the other ones.  Credit goes to him for the original and my apologies for bastardizing it.
Also hi - I guess I'm past lurking now.
EDIT: And lo, Lark did forget that paint saves in jpeg first, and the pixels did blur horribly.  But then she realized her error and did return to paint to color over the blurred pixels.
tl:dr - I fuxored, I fixored.
« Last Edit: March 29, 2008, 09:48:16 am by Lark »
Hey, if I put something witty in here, everyone will think I'm brilliant and cool!  Right?  Right??
« Reply #194 on: March 28, 2008, 02:31:56 pm »
Looks purdy gud... gud indeed.
