Author Topic: Eye Arr See  (Read 39780 times)
Eye Arr See
« on: October 05, 2005, 05:52:15 pm »
A few people have been asking me how to get to the Snipe Hunt chat, and while it should be up to them to explain to people how to do it, it's apparently not happening, so here I go helping anyway . . !
If you're using the hchat mirc and you're at #fybertech or #hazardlabs on Fybernet, you can type the following to open a new server window:
/server -m irc.esper.net -j #snipe-hunt
This will let you stay in #fybertech/#hazardlabs as well as go to where they're at.  If you've permanently switched over to the snipe channel already and want to get back to #fybertech or #hazardlabs on Fybernet, just use:
/server -m irc.fybertech.net -j #fybertech
And that'll open another server window back, leaving you in snipe chat as well.
If you happened to have gotten the Snipe Hunt version of mirc, I suggest you erase it, since CERTAIN DUMB PEOPLE I WON'T MENTION LIKE JAKAL decided to take my name and such off of it without asking me despite it all still being my code.  To make matters worse, he changed some command and variable names in the scripts I wrote which will only confuse you, and removed other stuff (like the mp3 player) which you might have wanted, for some stupid reason I'll never know.  Don't ask me to help you with that version cause I won't.
If/when they fix their own version, the above commands to open a server window back to #fybertech will still work if you take a notion you want to join.  But again, don't expect me to help you with whatever they put together, because that's their job.  I will however continue to support the hchat mirc and the fybertech version which will be released shortly, if you have any questions about those.
You can also ask general IRC questions here if you want, so feel free~
Re: Eye Arr See
« Reply #1 on: October 05, 2005, 05:57:08 pm »
I'd say make that first post from IRC burrito where you give a good tutorial to the whole thing.
Joefus
  • Click Out Field Commander
  • Heehehe
Re: Eye Arr See
« Reply #2 on: October 06, 2005, 04:05:38 pm »
Thanks for that command line Fyber,  I was really getting annoyed at having two irc windows open so I could hang out at both places.  This solves my problems!!
Re: Eye Arr See
« Reply #3 on: October 06, 2005, 05:33:32 pm »
Before mIRC had that feature to open multiple servers, I wrote a big script to do something pretty similar.  It wasn't nearly as good as how they handle it in the program now of course, but people were like "omf how are you just using one mirc".  But then it became obsolete and I cried a little and went home.
Re: Eye Arr See
« Reply #4 on: October 06, 2005, 06:44:14 pm »
lolz :D
Re: Eye Arr See
« Reply #5 on: October 25, 2005, 08:03:36 pm »
So Fyber, how can you set it so it joins Snipe-Hunt and Fybertech without going all retarded?
Re: Eye Arr See
« Reply #6 on: October 25, 2005, 09:18:37 pm »
D-don't go to Snipe Hunt?
I'll have to look into them shiznits.
Re: Eye Arr See
« Reply #7 on: October 27, 2005, 01:08:38 am »
It seems that Javachat's not connecting to irc. PLX EXPLAIN?
Re: Eye Arr See
« Reply #8 on: October 27, 2005, 09:39:19 am »
It H8s? Fyber prolly knows real reason.
Re: Eye Arr See
« Reply #9 on: October 27, 2005, 01:24:12 pm »
IRC is completly empty...I am all alone.
* Garshak builds Gar-chat system
Re: Eye Arr See
« Reply #10 on: October 27, 2005, 01:26:36 pm »
Gar-chat reigns supreme for 3.29 minutes
Re: Eye Arr See
« Reply #11 on: October 27, 2005, 01:36:42 pm »
Re: Eye Arr See
« Reply #12 on: October 27, 2005, 08:15:16 pm »
B-but, is Javachat borked, or the entire IRC server?
Re: Eye Arr See
« Reply #13 on: October 27, 2005, 08:21:46 pm »
You killed it!
Re: Eye Arr See
« Reply #14 on: October 27, 2005, 08:24:05 pm »
O SHI-
